steve050773
06.06.2006, 09:58 AM
Brian - good point. I forgot to mention that I have tested the motor and controller where I have disengaged the pinion from the spur and the motor runs smoothly. I didn't give it full throttle for fear of exceeding the motor's rpms, but I did go over half and it turned without hesitation.
The truck will roll smoothly under 1/8th throttle on concrete and pavement, but any additional throttle and I get the hesitiation. Its less of an issue on pavement, but if I roll into grass its a mess. It also happens in reverse on almost any surface.
Definitely think its a connection issue the more I talk through it.
