Batfish
Batfish's Avatar
06.14.2006, 09:13 PM
Here's a new update.
First, one picture:
Now links to 9 more - I decided to save on the low-bandwidth folks by not posting 10 pics in the same reply :)
http://i20.photobucket.com/albums/b2...14-2006-01.jpg
http://i20.photobucket.com/albums/b2...14-2006-02.jpg
http://i20.photobucket.com/albums/b2...14-2006-03.jpg
http://i20.photobucket.com/albums/b2...14-2006-04.jpg
http://i20.photobucket.com/albums/b2...14-2006-05.jpg
http://i20.photobucket.com/albums/b2...14-2006-07.jpg
http://i20.photobucket.com/albums/b2...14-2006-08.jpg
http://i20.photobucket.com/albums/b2...14-2006-09.jpg
http://i20.photobucket.com/albums/b2...14-2006-10.jpg
So...I'll recap and describe it as you see it in these pictures.
We (CCristo and I) pretty much share responsibility for this project, and we're both pretty pleased with it so far :)
The chassis is custom cut from 3mm aluminum and extended 1 inch (to make mounting the batteries easier). This makes the chassis approximately .5 inches longer than most of today's 1/8th nitro buggies.
A UE 105mm dogbone was used from the center diff to the rear diff. The original OFNA front dogbone was used from the center diff to the front diff.
A rear brace was cut to go from the center diff to the rear diff. This is where the ESC is mounted.
A front brace was cut to go from the steering posts to the center diff. This holds the UBEC and the Nomadio Sensor transceiver.
The steering linkage was swapped from the right to the left side to accomodate the motor, which is mounted towards the front of the buggy rather than the rear (also to increase room to mount the batteries and help off-set weight).
I got a motor mount that Mike had originally prototyped for a HB center diff and we adapted it to the OFNA center diff, then mounted the motor forward with the pinion facing the rear of the buggy.
The steering servo is mounted laying-down on the chassis. It is a JR z8800t servo.
The brake servo (mechanical rear brakes) is standing up next to the center diff using Traxxas servo mounts. It is a BlueBird 621MG servo.
I swapped the c-hub suspension that was on the vehicle for the PBS suspension (personal preference).
We abandoned the E-Maxx battery trays in favor of GorillaMaxx straps and Associated battery cups. I cut the end cap from the cups and mounted them to the chassis to stop side-to-side movement of the batteries.
The motor is a Lehner 1940/6 hi-amp and the speed controller is the BK Warrior 9920. The batteries are FMA/Kokam BalancePro2S 2S2P 6400mah 20C packs, two of them in series. I use two of the BalancePro chargers to keep the batteries charged up during the breaks between practice/racing.
I'm hoping to remember my camcorder this Sunday for some video on the outdoor track. As it is now, the buggy easily keeps up with the nitros and can even outrun some of them. It definitely takes the prize when it comes to accelleration. :)
Feel free to ask any questions, as I'm sure I missed something of interest to someone.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
