Thunderbruiser
Thunderbruiser's Avatar
06.20.2006, 01:16 AM
well you'll have loads of slip....mods are
using associated diff balls in the tranny two packs(this is supposed to increase the diff action)
Either Run Heavier Spring(so slipper will be tigter) or run rs4 hub and eliminate slipper all together....
I also hear you can use ofna diffs...but e-maxx would work cause it's 32pitch gears for more options
also you'd prolly wanna modify your motor plate
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
