06.20.2006, 01:59 PM
newe, I just found out from the UE board that the UE are longer....I'll post the info here..for all to use..
bnighs
You really can't measure the difference. The UE CVDS shafts have the ball on the end and the part that goes in the knuckle has the cup. The MIP's are the opposite, they have the cup on the shafts and the ball on the part that goes in the knuckle.
MonsterMaxx
You'd need to compare the design length of the assembly. The length of individual pieces is meaningless.
Then you have to establish where you are going to measure from and to. Are you going to butt the drive cup against the bearing or is there a centering mechanism with the drive cup and hole in the output shaft.
Our assembly should be 2-3mm longer than MIP since the trx 2.5 suspension is 2-3mm narrower than the UE ones.
__________________
Originate! Never Duplicate
Sales @ UEusa.net
