cemetery gates
06.20.2006, 02:31 PM
Originally Posted by neweuser
thanks! i'll play with it this weekend. So you can't seethe cuts from the outside that are made on the in? I was going to do that but was a little worried.
you can a light box just makes it easier to see. xxx main makes pre-cut flames and other designs that go on the outside of the body and paint masks and internal decals that go on the inside of the body if you are not into cutting your own flames.
here is a link from tower http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
