Feigao RPM limit?...
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
Feigao RPM limit?... - 01.21.2005, 06:28 AM
Hey there,
I've just been looking around at more info on the Feigao motors, and found out that they have an RPM limit of 50,000 (and apparently you shouldn't really go above 40,000) before they begin to fly apart. In my Dag I was planning to run a pair of 7S's on 8 cells and maybe get those from somewhere else...but after working it out, that would be hitting about 49,000rpm (ish)...which sounds a little risky to me. In which case I was going to run the 8S, but even that will hit about 44,000. Will I be ok running the 8S? I doubt the motor will even get a chance to max-out, but I just want to make sure.
One more thing... is the reason that BL motors are faster because the RPM doesn't drop as much under load as brushed motors (because of the torque)? It's just that my current 14T brushed motors already hit 42,000rpm under no load. With these motors my Dag hits about 30mph (but with little torque)...and I don't want to buy an expensive BL setup if it doesn't offer much performance gain.
Thanks for any help!
