squeeforever
squeeforever's Avatar
06.22.2006, 04:56 PM
Sounds like a good setup, however, you will have to charge those packs in parallel to charge them both at the same time. You can charge them as a 3S2P at 7.5 amps (the max for that charger I believe). It would take around an hour and 15 minutes I would guess since that would be slightly less than 1C.
