cart213
cart213's Avatar
06.22.2006, 05:38 PM
It shouldn't be the torque causing it to veer. My MT2 doesn't veer, and my 540c-9L has a lot more torque than your 380c-6L. I'm not sure about the diff fluid. I just use grease in mine. How did you seal the diffs?
Btw, the gears are noisy on these, and not just the spur/pinion. A lot of the noise comes from the front and rear diffs.
