06.25.2006, 08:48 AM
Are not the C rating and the mah somehow correlating?? If the mah doubles the C rating will... That is why you can charge a 4000mah pack at 1C (4 amps) and a 8000mah pack of the same cells at 8 amps.
Brian, I understand what your saying. I did some more figuring last night and it just didn't work out. I'm not sure but if I remember correctly, there 4000mah packs are 40 amps cont.
EDIT: I just looked at it again, and the 4000mah cells are good for 40 amps cont. but where you linked, says 5C, which isn't write. I think I know why. A while back be was using other cells rated for less amps. Maybe he didn't change that on the site?? Just a thought. But the cells are 40 amps cont...
