06.27.2006, 10:32 PM
Another update:
Well it wasn't as successful as I orignally thought. Apparently going to full brakes from a fast speed causes the pinion/spur to grind, so it chewed up the spur a little. It looks fine but makes a terrible noise now. The problem is there's no slipper, it's just a gear that transfers to the front and rear diffs, so I'm thinking about switching to a slipper or maybe some kind of center diff from a buggy?
Even worse is now it's glitching no matter what I do. I've moved things, wrapped the receiver in foil, changed radios and batteries and it still does it. I'm using a Futaba 3PM FM and I tried an old Futaba PCM. The worst part is it started for no reason, it was fine one day and now this. The only thing I haven't done is try it in another location to see if something around here is interfering.
Oh well. :031:
RC10T2 - Novak SS5800 - 7-cell GP3700
HPI RS4 Nitro MT - Mamba Max 5700 - 2S 5500mah Lipo
MRC Thunder King - Mtroniks Truck ESC + Feigao 9L - 3S 6000mah Lipo
