MetalMan
MetalMan's Avatar
06.28.2006, 08:14 PM
If the 2 battery packs are wired in parallel, then the LiSaver is connected to both batteries. In a parallel connection, both battery packs will be at the same voltage all the time. Another way you could connected the LiSaver is to the battery input leads on your speed control. This would remove any hassle that you might deal with by having it connected to your battery(s).
