Mark Fradkin
Rad Frad
06.28.2006, 09:28 PM
Thanks Metalman for your reply. The 12020 has 2 red & 2 blk coming out. I have taken one red to each 5s and one black to each 5s via deans ultra plugs. Mikes new "Car Version" Li-saver uses an ultra plug male & female harness w/ small gage wire hooked direct to li-saver . this is inserted btween the 12020 & battery,this takes care of
one 5s apachee, Can I make a simular harness for the other battery combine them together for a single parallel imput to the Li-saver?
Also I have the UBEC hooked to one 5s only w/ a switch in line. Is that OK? Will the ubec run one battery off or will Li-Saver detect that. I have disabled the 12020 bec.
thanks Mark
