06.30.2006, 09:53 PM
You run a 125 though If I am correct. It seems better this time.
I still running the same stuff I had with the 9920 and it did good.
spektrum radio system. It is only at start up when you plug batteries up and try to move for the first time. The esc got to a balmy 85 degree f after 6 mins. I don't think that is to bad.
Yeah, mine is a 125B. I also am running a Spektrum system and a UBEC. However, fearing that the power from the UBEC might be "noisy" I added a 1,000uf 10v capacitor to help filter the power. I also added a switch so the UBEC has time to power up and settle down before I switch the power to the receiver. Maybe those things make a difference?
85 degress is not bad at all. My 125 got to 120 degrees in my cool (~65) basement after about 1/2 hour. When outside it gets hotter so I added a heatsink. Much better now.
