07.07.2006, 04:56 PM
Originally Posted by neweuser
So maybe i'd be better getting the 12020?
Yes and no. Yes because it handles almost as much current, no because it does not have a built-in LVC for Lipos, is not as smooth running, less programming options (out of the box - not sure what is possible with the BK software and PC cable), is not as easy to mount, and definitely needs to be padded since the circuits are right there under the shrinkwrap.
Since the Quark says it is rated for 6s/18 cells, you could use it and if it blows, it would be under warranty as it was being used as instructed.
