squeeforever
squeeforever's Avatar
07.08.2006, 10:25 AM
Originally Posted by Sylvester
I dont understand, if you want to create a by pass shock you'd need alot thicker shock body to accomodate the use of a thicker spring. (Just like PL's) . Im sure its possible, with a little custom work, but not with ue or traxxas shocks, thats for sure.
Well first off, the "By-Pass" shocks, have no spring. Second, it's not really possible. The way the By-Pass shocks are designed is so the when there compressed, the oil is forced to go into the outer chamber inbetween the heatsink and the inner body. Look at Pro-Lines website. It has a cut-away and shows how they work.
