07.11.2006, 10:29 PM
Wow, that sucks. Sounds like it will probably happen again then no matter what you do. Well, in that case, you could program it the way you want and then just solder across the two solder pads. If the gap is a little too wide, use a very short piece of wire to bridge it. You'll have to desolder them again if you ever need to re-program it though...
