Serum
Serum's Avatar
04.17.2005, 04:55 AM
Well...
It does have got more torque BUT.....
Here is a little thing, you need to keep in mind;
The power a motor can give will not be any higher than the power the batteries can deliver.
A lehner basic motor is able to pull a 100A from your packs. So is the 9L, if it does pull that 100A, the voltage drop of the cells will be about .85- .9 volts, X 100A = 85-90 watts per cell. time the amount of cells lets say 12, would result in 1020-1080 watts
That L serie is a motor that can take the maxximum power from your batteries, so is the XL.
