07.17.2006, 09:37 PM
Red jumper is for programming.
Black is the BEC. Pull the black one out to disable the BEC if you are using 12 cells or more, have more than one servo, are using a receiver battery pack, or an external BEC. It shouldn't have anything to do with programming.
If you are having trouble teaching the ESC your transmitter, make sure your EPA is set to default. Also, try reversing your throttle on the transmitter.
