07.19.2006, 11:08 AM
Originally Posted by RC-Monster Mike
The Lehners will run a little cooler than the feigaos. A lot depends on how you use it as well. If your just bashing around, you likely won't have extreme heat with the lesser motors. If you plan on long races on a track, the Lehner "19" series is the answer.
I was looking at the 1920's you do have in stock and thought maybe one of them will work if I can rearrange the windings for a higher turns ratio. Before this is done, will the various speed controllers (BK, Quark, Castle) be able to hook up to wye configurations? All the inrunner motors I know of are delta wired, so I don't know if the ESCs can properly drive and read wye configs. Also, do you have the formulas and such for re-wiring them? I think I had found a document explaining this at the bk-electronics website, but they have since re-structured it and I can't find it now.
