Gustav
Gustav's Avatar
07.19.2006, 03:02 PM
I'm using 3.3 parts on my g-maxx,3.3 knuckles,arms,bulks,towers and sliders.I'm using 1/8 diffs in ultralite cases,7075 cups and centre MIPs though.
I made diff outdrive shafts for the sliders,the distance between the drive pin holes is accurate to get the grub to line up with the slot in the bulk to get a driver in (see pics).Then the slider is shimmed against the bearing race which also prevents the bevel gear mesh from tightening(the shaft can't push in)
ID:	1472   Click image for larger version
ID:	1473   Click image for larger version
