Gustav
Gustav's Avatar
07.19.2006, 05:17 PM
If you can find some better belts that are the right length and rig up a tensioner for both belts then it would work no problem.1/8 on-road all use belts albeit wider ones.The belt materials have improved,losi make good heavy duty belts but it's a case of finding the right lengths.Maybe searching tower for alternative belts that might fit since they put the specs of most things on there.
Try running more tension first though,that rear belt definately looks like it needs something:005:
