Thread: 1930/10 / 12020
Gustav
Gustav's Avatar
07.22.2006, 07:03 PM
I was meaning play between the bearings,all my 19 series were shimmed perfectly from the factory.
Is the motor new? ,if it's used it may well be damaged from what you describe,i definately wouldn't run it if it does that.hopefully hasn't killed your esc aswell.Man you're having some bad luck at the moment,if the motor is the culprit then hopefully the quark and BK are OK atleast.
