07.23.2006, 08:16 PM
Originally Posted by squeeforever
Actually the sliders are smaller than the Revo ones. There the same style, but slightly smaller (about the size of a Maxx slider). Brian, the Traxxas cvd's and the MIP upgraded ball diff would be a nice upgrade as well as GTR hard anodized shock bodies and TiNi coated shock shafts with the little Traxxas shaft protectors, aluminum caster blocks, ect :p.
Do you have a link for the upgraded diff? As far as shock bodies, I have a TiN set from my dismantled Revo (v1) that I could use, although I probably should change the oil. We'll see. I want to keep the weight to under 4 pounds. I do know I want to get the RPM bumper - I am a terrible driver. :frown:
Oh, and I want to get the tie bar that reduces the rear toe-in. 4 degrees is too much for me. I want 1 or 2 degrees, but am limited to as little as only 3 degrees.
