07.24.2006, 04:26 PM
You'll also need to ugrade to CVD's all the way around. Oh !I almost forgot . Welcome to the forum. There is a ton of usefull info around here. You just have to look/search for it. If you can't find it just ask and someone will help. Squee is right about the hvmaxx. It might be a good starter if you started with a stock emaxx and was looking for a little more power. I'm sure you want something at least as fast as your nitro maybe even a little more. If you can deal with the hassles of the nitro then a custome setup should be fairly easy for you. If you think that you will want to upgradw to lipo's at some time in the future then I would start with them. Hate to have to buy 2 chargers. I'm not sure if there is a charger on the market that will charge all 3 types of batts (nicad, nimh, and lipos).
So many toys and so little time
