squeeforever
squeeforever's Avatar
07.28.2006, 08:04 PM
Originally Posted by MetalMan
If the battery bar is loose, then you'd still get steering. A steering servo uses about 2-3amps max., which a loose solder joint can easily provide. But when your motor is trying to draw 30+amps, then a loose solder joint will show itself. I'm not saying that it is a loose solder joint, just pointing out that like squee said, it's a possibility. If you have any other battery(s) to try out, then you can eliminate the battery as the problem.
Yup. My servo still worked as well. Like I said, its just a possibility.
