cabking
07.29.2006, 06:18 PM
Originally Posted by Gustav
The problem with just cutting holes in the body is it opens out after it enters and the air slows down so we're not really getting all that much cooling at these relatively slow speeds,i think maybe what we need is a tube or tubes going to the areas we want cooling.
Gustav, I recon a couple of ice cream cones through the windscreen could do the job.....they would have to be double scoop size obviously.....
That just leaves you to work out how much to bite off the end.......:004:
Ive always run my fans on 16-18 cells ( knowing sod all too :027: ) The one thing I am sure of now, is the neon ones seem to last consideably longer than the standard fans.......I plainly have no idea why this would be, just though id pass it on.
