07.29.2006, 07:04 PM
Originally Posted by squeeforever
Maybe you can use a Revo aluminum diff cup? The appear to be the same correct?
Nope, not even close. Each half is sorta cone-shaped. One half is a little deeper - that one has the ring gear. So, the ring gear wraps around the diff making it sturdy. Looks sturdier than a Revo diff. You can see what I'm talking about here and here.
(Edited to answer your edited question :)): I don't think so, but time will tell. Stock 30k seemed way too loose. I guess I'll find out when I get this done and try to turn! I used 50k mainly because I had it. I forgot to pick up stock 30k diff fluid while at my LHS. :(
