danverz
08.04.2006, 10:43 AM
You surely will find it a really great motor. Tons of power without heating up.
You also can keep high final ratios if your controller can handle it.
I'ts a pleasure of motor.
I just advice you to buy the hi-amp version. You surely won't need to change the
motor to a 30 volts one and the female connectors on the non hi-amp version are
not so good. I think it would be better to directly solder the esc to the motor
as the hi-amp version oblige you to do.
Ciao
Daniele
