starscream
RC-Monster TQ
starscream's Avatar
08.13.2006, 03:48 PM
I always thought the channel 1 was steering. That is the slot I plug the steering servo in. Channel 2 or slot 2 for esc.
If you got the epa set on the channel to zero that mean when you push it in brake or reverse. The esc should have the same signal as netrul.
CHC, you are absolutely correct. Sorry, I guess I shouldn't try to be technical that late at night :005:
The HV fits my needs perfectly since I only use my esc's as foward only.
Serum,
I recently got the castle Link and updated the software on the HV esc but haven't used it since I updated the software. I will test this out on my project truck and see if its fixed. If the issue has been fixed, this esc may be the ticket for my higher volatage applications :017:
Ha Ha
