standard_63
standard_63's Avatar
08.16.2006, 09:52 AM
If you're not going to use lipos, 14 cells, 9920, 7XL will be perfect. I do use a UBEC, and geared so the motor only hits 155f I can run for about 6-7 minutes before I thermal. Given the abuse my ESC has seen I do not think this is bad. The problem seems to be the constant high current and long runtimes make things heat up too much...
Please tell me that's not smoke I see!
