Originally Posted by aqwut
instead of my 2280, I was goin' to get the 3080, but then .. I thought.. too much.. and it probably would be too much.. a 4 lb motor.. hahaah.. I did try sticking my 2280 directly to my rear diff on my E-maxx.. the motor handled it no problem.. @ Fine designs there's a cat with twin 3080... that's nuts.. I guess he only esc for it are the 40.160wk.. (I had two of these at one time) but the 3080 is definately an overkill.. but I really would like to see someone do this... C'mon.. YOU CAN DOOOOeeeeT!!!!
I was slightly inspired when I seen your truck. I though, I need some overkill!:018:
What was top speed like with the direct drive?
Brain, that stuff looks like it would be good, i'd definetly have to make a rear motor support, though that metal helps alot.
So, to find some 10mm pinions.
I think with this motor, the spur gear will be smaller than the pinion.
