crazyjr
crazyjr's Avatar
08.18.2006, 09:13 AM
I had a similar problem with a Novak ss5800, what i ended up doing was to get all wires away from the reciever, all esc wires on the esc side, even the battery wires. I also drilled a small hole in the antenna so i could run tie reciever antena wire into the antena tube without going through the chassis. it worked great till one day i put the battery in the opposite way as described earlier and the interference came back. Not sure how it will work on you're alumnium chassis, but hope it helps
