08.18.2006, 11:42 PM
Interesting lesson. Now that I'm out of the Nitro scene and don't need WD-40 for after run oil, I just use it to help camoflage the scratches in my lexan bodies. Plus, it makes it nice and shiny. :)
Does it really remove lipstick from clothing without further staining the garment? Lipstick is greasy so I'm thinking it might work on similar grease stains? Also, you said "...has washed and dried a tube of lipstick with a load of laundry..."; does this mean it will remove the stain even after it has "set in"? Usually, once you wash/dry the garment, the stain is in there for good AFAIK.
