RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.27.2005, 06:17 PM
First of all, welcome to the forums! Now, to your question:
The input shaft (top shaft with the slipper clutch) has to be cut to fit inside the new aluminum case. This is easily done with a dremel. Then, the extra gears are taken out. A pretty simple mod, actually. You are only 30 minutes away, so I could easily help you with this if you needed it. Of course, the tranny is unavailable at the moment, but should be available in a short amount of time.
