squeeforever
squeeforever's Avatar
08.20.2006, 01:42 AM
I would say it does 45+, got a center diff, etc. Anyhow, You dont have the Combos...the Hybrids are the ones for 1/8th scale gears. You need the Hybrids front AND rear. Both with 1/8th scale gears. The MIP CVD's will work fine. Just gotta get the cups for the pinion on the Lightning diffs you bought. All you need is the cups and the rear setup just like your front. You did buy the rear Hybrid housing as well, correct?
