Originally Posted by jhautz
On 5s or 6s lipo, you will boogy the blades right off of the fan.:005:
Not to mention the fan motor will burn up in no time. On 5V off the BEC you can run whatever battery you want and it doesn't matter.
12V fans are fine if you are running only 12 cells.
Hi, I am running a 12 volts 6x6 fan with 5S lipo without problems since a month or
two.
Daniele
