Thread: Jammin Truggy
glassdoctor
TEAM FUSION
glassdoctor's Avatar
08.23.2006, 12:01 AM
I got to run just a couple laps at the track today.... I think I will move the esc to the rear and I need to get the new motor mount done. The plastic temp. mount isn't holding the motor mesh right. It lets the motor slip away just a bit.
I seemed to run a little nose heavy, which can be addressed with some setup adjustments, but I might as well start by shifting some weight back and go from there.
My buggy has had the same tendency but I can't do much about the layout there... I need to make some setup tweaks to try to fix it. I did run some of the fastest lap times when I raced it though so it's not exactly a pos. :D
