Serum
Serum's Avatar
04.28.2005, 01:04 PM
For 5 volt, you can take the red wires..
If you need 12V, use the yellow wires.. ;)
Look at the diagram i posted before, to start the ATX powersupply connect pin 14 to the ground. And make sure that you use a load on that powersupply. (these types of powersupplies don't like being unloaded) i used a 15 ohm resistor inside the powersupply to give it some load when the batteries are full. (placed it in the airflow of the fan, its a metall case resistor)
Join about 6-8 wires together.
