09.04.2006, 10:28 AM
I also think that battery setup should be fine.
You can use the Smart Guard 505 with it connected only to the battery. I'm using that balancer with my batteries now, and since you can only charge up to 3amps with it between the battery and charger, I am charging with it separated so I can charge at higher rates.
You could use two LBA10s networked together, but as has been stated you can't charge them on two different chargers.
What you could do is get two SM505s and charge each battery separately on your 109s. That would end up being the least expensive balancer setup.
