neweuser
neweuser's Avatar
09.09.2006, 09:55 AM
Thanks Brian G! I think I got this down a tad bit. i sent you a reply by the way. I'm not getting enough volts thru to the charger, nor to the battery packs....So i'll need a resistor. Now you too much or not enough? Also, There is no way in hexx i can get 7 wires together on one deans! Any solutions? And why do you have deans on the 3.3v and the 5v, what do you use this for? charging lesser v batteries?
