HotnCold
HotnCold's Avatar
09.13.2006, 04:54 PM
Originally Posted by dda01015
If I add a fan with a thermal patch to my 125B on the front and/or back, and not the heat sink strips, do you think it will help to cool it? I'm thinking about milling out a motherboard heat sink too, and using that fan. I heard the adhesive alone is $50.
Yea - putting a heatsink on the bottom of the spee controller will help - you need a compound to effectively transfer the heat from the speed controller to your heatsink - an efficient transfer of heat will reduce the temps substantially - i went from thermaling after 6 mins being easy on the throttle to 35 mins and hammering the snot out of the throttle trying to thermal her.... Good luck.... btw - check out this stuff called artic silver - works awesome
Hows that "Hope and Change" working out for Ya???
