Serum
Serum's Avatar
09.16.2006, 01:49 AM
that's how i used mine, you only need to look at your plugs as pairs, coming from your batteries. You can easily put them in series, which normally is the goal.
The powerpoles are very nice. They are a clamp-on, so you can easily clamp in an extra wire for the ubec. I think i would put flux on the wire before putting them into the powerpoles, clamp them, and add a bit of tin.
You can't forget to put the socket on them either, you put the socket on from the side of the plug, not from the side of the wire.
