Dismantling a 1930
Hayden
Dismantling a 1930 - 09.17.2006, 02:08 AM
Before I dismantle my 1930 is there warranty on these things? It came with basically no specification on the motor.
What happened I was running it on my test bench with a medium APC propeller and after 1min of running and stopping…etc (testing it) it smoked the battery was cold and the speed control was not even warm practically room temperature did the motor fail? or was there too much load?:026:
I’m eager to pull it apart. how do you get it apart? do you mount it on a board and twist the motor can? So the can comes away off the purple front mounting plate.
OR do you desolder the end plate?
and the esc was a mgm 12012 runing a flight power 4cell lipo
