Finnster
KillaHurtz
Finnster's Avatar
09.24.2006, 02:30 PM
Originally Posted by squeeforever
The output shaft will be shredded in no-time. The idler shafts are good though since they don't have any stress on them...
What part of the output shaft do you think will be shredded? The shaft itself is thick, so I don't see that as a prob there. The dog gear is plastic, so if that holds up I would think a alu ~8mm hex would. The only questionable part in my mind is the actual output shaft connectors to the center drive shafts.
Not trying to be arguementitive, just looking for elaboration... The idler gear shaft can be had seperately, but for $6 I wonder if its worth a shot?
Not looking at the input shaft at all, that def seems like a deathwish.
