Originally Posted by Serum
With that car, you can fit a schulze 40.170 without finding it back..
You need a map to locate it.. LOL
:eek: the 40.160 is a little more than I was planning on spending for this project. Though it would be nice in a unlimited world, but probably overkill.
Originally Posted by cart213
That thing is big! I'd be surprised if you could keep the weight under 9.5 pounds. I think most 1/8 brushless buggies weigh about 8.5 pounds. Looks like a fun project, though!
After I stripped all of the nitro stuff off of it, I piled everything up that I think will go into it and it came in right about 8.5 lbs I am assuming it will go up slightly due to additional screws that werent on there yet and all the minor stuff. I used a set of 6s 4200mah lipos for my weight also. so I added a pound to go to the 8000mah lipos. Even if it does go over the 9.5lbs, I dont think it will be a problem. I run my revo at a shade over 11lbs.
