Thread: Quark Question
09.29.2006, 03:23 PM
This is what I was referring to: page 3 of the manual.
Li-Poly High - Select when the Battery is compatible with the voltage in use. Faster throttle response time and increased torque compared to when Li-Poly Normal is selected.
Li-Poly Normal - Select when the Battery capacity and discharge rate are lower than voltage in use. Slower throttle response and lower torque than when Li-Poly High is selected.
You might want to look at some of the other settings as well.
