Cartwheels
10.09.2006, 07:15 PM
Originally Posted by neweuser
How are you guys getting the Quark apart anyways?
If you are talking about how to open the case, in the center on of the top plastic piece between the plastic and aluminum casing, stick a small sharp flat sharp screwdriver, opening the aluminum casing just enough for the top plastic piece (there is even a small slot there like it was made for a screwdriver to fit) to come outward.
I'm alittle curious about the new Mamba Maxx. I have a brand new in the box Quark and a Quark with like two runs on it. I'm going to Ebay one of them to get some cash to buy a Mamba and check it out. I'm running 4s lipo and a two pole motor which is the only short coming of the Mamba maxx (low volt rating and no 4 pole motors). Its cheeper than buying a Neu motor and I love my Mamba 25.
I love the Mamba Max, but the Quark I believe just feels better overall for 1/8. When I had the MM in my buggy over all it works pretty good, it just feels smaller. Not quite as much take off power. Occasionally, from a standstill to full throttle would give you just some clicking as if I was holding the buggy. Hard to explain. If you have a light 1/8 setup it would probably be ideal.
