Thread: lipo
lipomax
05.13.2005, 01:08 AM
With the XL3100, you can pull about 100 amps so you need to get lipos that can give out 100 amp peaks w/o exploding. My recommendation is to go 4s 8800 mah. So, that's two 4s packs in parallel. Each of those 4400 packs cost like 180 bucks so you're looking at 360 bucks just for the batteries!!!! But, as long as you don't puncture them or over discharge them, they can safely handle the current draw. In addition, you'll get 20 minutes easily with 8800 mah if you run in first gear mostly. The other affordable lipos are good, but they all stand the chance of blowing up because the 3100 motor can pull 100 amps.
Honestly, at 15 years of age, don't do it. Too costly and dangerous. You might burn your house down and because Lipos are relatively new, they're expensive and not perfected yet. Wait a year or two, you'll be more responsible, and Lipos will be much better and cheaper. Just 2 years ago, the best lipos were way weaker and cost a lot too.
