mrsoundman
10.10.2006, 06:04 PM
The motor mount is 7075 aluminum. I mounted the motor laying down on the motor mount and not up in the air, to prevent stressing the motor mount on hard landings. I figured just regular aluminum angle would have worked, but had access to the good stuff and used it.
Your Mamba Max setup is exactly what I was thinking, Very Nice Setup! My local industrial supply shop stocks nylon, alum, steel 4-40 standoff's in varying lengths - so it shouldn't be too hard to do. I still have some left over carbon fiber and could easily make a larger center diff top plate to accommidate the esc, standoff's, and fan.
