jhautz
jhautz's Avatar
10.14.2006, 04:41 PM
Originally Posted by James
I have the hornet but the tranny/axle housing is craked, so when i replace it i was going to ge tthe grasshopper one instead so i cna gun the mamba system. I can get the hornet part, and run a 540 size motor to. I have a could i run the wanderer 12s on 8 cells? would that have to much torq? how fast would it go?
If you know the gear ratio you can use the speed calculator that BrianG put together.
http://scriptasylum.com/rc_speed.html
Without knowing all the particulars of your setup its hard to tell how fast it will go. Just plug in the info and it should tell you a pretty decent estimate anyway.
to make it...
or break it...
Silent...But Deadly
